Dual XGPS150 5Hz support
Re: Dual XGPS150 5Hz support
Please check the articles on this thread (and others). Several users had problems loading the update. Changing to another machine / different USB port / Windows version helped. On the firmware update in general: this 4/5 Hz firmware has been added as a special edition for LapTimer users (and probably others with high update rate requirements). This is the reason it is not preloaded always.
wtam608
Post by wtam608 »
Just purchased Dual 150a. It came with 1.3.1 firmware. It seems to be working without any issue (In the Satellites and Senor List options). However, after finished the run... from "Lap List" speed information shows only ave of 1 mile, GPS sensor show "Internal @ 1.0 Hz".
Do I need to turn off the internal GPS? If so, how - I don't see any way the IOS can turn off the GPS setting. (ISO 7.0.4)
Thank you.
wtam608 wrote:Just purchased Dual 150a. It came with 1.3.1 firmware. It seems to be working without any issue (In the Satellites and Senor List options). However, after finished the run... from "Lap List" speed information shows only ave of 1 mile, GPS sensor show "Internal @ 1.0 Hz".
Thank you.
In case LapTimer detects a XGPS, it turns off the internal GPS automatically. No need to switch it off...
Nevertheless, the above message means the Dual is not currently connected to LapTimer. Check the following items / follow the listed steps:
  • Check LapTimer / Settings / Expert Settings / Accessory Tweaks / Use Accessories -> needs to be ON
  • In case that doesn't help. Turn off the Dual, send LapTimer to background. Turn on the Dual again. Make sure the Dual and your iPhone connect (check the the BT icon in the status bar. Pull LapTimer to foreground and check the GPS source again (Sensor List).
Airplane mode turns off the internal GPS as does turning off Location Services in the Settings/Privacy menu. Turning off Location Services does other things as well which may or may not be advantageous. In Airplane mode, you have to turn Wi-Fi and Bluetooth back on in the Settings menu.
When I have communication difficulty with my XGPS160, I go to the Bluetooth menu and un-pair (forget) the device and then pair it again. You can have a situation where the GPS shows 'connected' in the Bluetooth menu but HLT doesn't get data. I'm pretty sure that's a problem with iOS and not Dual or HLT. It's not as bad in iOS 7 as it was in iOS 6.
