LapTimer ‣ Analysis ‣ Realtime ‣ Engine is exclusive to LapTimer Grandprix and not included in Petrolhead. Two options:
#1 upgrade to GrandPrix from LapTimer ‣ Administration ‣ Add-ons ‣ GrandPrix Upgrade
#2 use the limited set of engine data shown in LapTimer ‣ Analysis ‣ Realtime ‣ GPS
On #2: once you connect an OBD adapter in an app edition not supporting Engine View, the GPS View will change and show a limited set of value in the bottom row. Tap the right most gadget to flip through channels available.
OBDII Data
Re: OBDII Data
Great, thanks! Will update to GrandPrix edition, just wanted to make sure it's the correct one.
Re: OBDII Data
Any idea why I can't see oil temperature? I can see all the other live data, except oil temp. I'm using TONWON BTLE with GP Edition with a Porsche Cayman 987.2.
- PitrsRS
- 20 or more Posts ★★★
Re: OBDII Data
Hi, that´s quite normal on "VW" cars. Not every car can provide oil temp via OBD dongle, even if you can see temp via VCDS software or on dashboard etc.west1785 wrote: Sat Apr 24, 2021 6:11 pm Any idea why I can't see oil temperature? I can see all the other live data, except oil temp. I'm using TONWON BTLE with GP Edition with a Porsche Cayman 987.2.
I tried it several times on different cars. Without success (Toyota Yaris 2016, Skoda Octavia RS 2010, Skoda Fabia 2018 and Leon Cupra 2016)
2016 SEAT Leon CUPRA 290 ST
- PitrsRS
Re: OBDII Data
Or you can try to set Custom PID in the app, then, maybe it will work.
Here is the list of PIDs
https://en.wikipedia.org/wiki/OBD-II_PIDs
Re: OBDII Data
Thanks, I'll give it a try.
