Only tested it for a sort time, but it seems that Gear info is not accurate, it says 1st Gear when in 2nd, and when the car slow down to stop, it shows "-" in the gear. It run fine with my old Wifi ODB adaptor (but it lost it
1) Is there a setting(s) that I should check?
2) Should I be getting slightly faster data update with the Kiwi3?
3) what's the max data rates I can get from this car's ODB / CAN bus?
Thanks.
