Page 3 of 8
Re: roqyBT4 and Bluetooth OBDs!
Posted: Tue Oct 04, 2011 5:11 am
by doborder
If u are able to support two BT device such as gps and OBD info, will so much data make the connection unstable?
Posted: Tue Oct 04, 2011 4:27 pm
by roqyBT
@Doborder
Yes, I'm working on a version to get multiple connection at the same time (GPS+HRM, GPS+OBD mainly).
I need to test it to get the Apple bluetooth stack stability. With 1Hz GPS and 3Hz OBD, I think there is no issue. With 10Hz GPS and 10Hz OBD, I don't know, it needs to be tested!!!!
Roqy
Posted: Tue Oct 04, 2011 11:09 pm
by doborder
Roqy,
I have a 10hz gps qstarz 818 as well as OBDKey which is running approx 3hz on my car. I would be happy to beta test it for you. contact me at
mchangdo@yahoo.com
Thanks for your good work!
Posted: Sun Oct 23, 2011 9:19 am
by Fobio
Hi roqy and Harry,
I just got the Lap Timer Pro and roqyBT working. I have the following BT OBD2 dongle:
This dongle works with my laptop with a continuous connection that avg 10hz.
However, it won't consistently connect or stay connected to Lap Timer Pro. Using the Timer or Timer/Video, the OBD data would come up intermitently and is not usable...in fact connection is dropepd 80% of the time during logging. Again, I have tested the dongle with a laptop, and it works: connects, stays conencted, and sends data...with the iPhone 4 and Lap Timer Pro, it won't even stay connected.
Please help.
Other than this, the program is working great. I look forward to being able to tether a 10Hz BT GPS receiver and 10Hz OBD2 BT dongle to Lap Tiemr Pro!
Posted: Sun Oct 23, 2011 9:26 am
Just to check if it is the same pattern like the one with WLAN dongles, or a different one: it connects to the OBD, shows some OBD data (best seen using the Speedo view), works for approximately 60s, drops connection for 5 seconds or so, reconnects again, etc? Or a different pattern?
Posted: Sun Oct 23, 2011 11:27 am
by Fobio
Harry wrote:Hi,
Hi Harry.
I can't say because I haven't seen the Wi-Lan issue, tho I've read briefly about it and briefly thought they were related. Anyway, for me, it'd work for less than 60sec...then would be disconnected for anywhere from 1 - 2 min then connect for maybe 10sec. The highest rate it connected was also 3.7Hz.
Thanks for the prompt reply!
EDIT: I have just updated with the latest version. I'll try again today in a few hrs and report back.
Posted: Thu Oct 27, 2011 10:46 pm
by Fobio
Updated app. No change. Same behavior.
Posted: Fri Jan 06, 2012 1:59 pm
by manucc1º
Fobio wrote:Hi roqy and Harry,
Please help.
Hello.
I would like know if this obd II dongle is compatible with laptimer pro withouth need of doing jailbreak to the iphone.
Thanks.
Posted: Fri Jan 06, 2012 2:04 pm
Bluetooth dongles generally requires a jailbreak to work. To my knowledge there is no Apple certified BT dongle available at all. Please check
http://www.gps-laptimer.de/Compatibility.html for a list off supported devices.
Posted: Fri Jan 06, 2012 2:07 pm
by manucc1º
And it's possible integrate roqyBT4 on laptimer?
