Crash When Accessing Lap Charts
Re: Crash When Accessing Lap Charts
The crash log FAQ is here: viewtopic.php?f=8&t=1115
tulloch
Post by tulloch »
I'm afraid not, otherwise I wouldn't be messing around with Xcode. I've no idea why though. There are some crash logs in the PC location referenced but not the ones I need.
17.4.3 started crashing on accessing the yaw rate chart again. I made one run and it worked fine. After the next run, it started crashing. After recovering from the crash, it said that there were a lot of database errors that had been corrected. I had deleted a track and several laps from the database because the autocross was at the same location but the course was, of course, different. Do you need the logs or should I wait and install the next bug fix version to see if that fixes it?
Yes, there has been amother issue in the taw rate diagram that will be fixed with the upcoming bug fix release (submitted already). No need to send, please just try it again once you have 17.4.4 installed.
tulloch
Post by tulloch »
No crashes for me in charts with latest update. <fingers crossed>
