Dual XGPS160
Re: Dual XGPS160
... and here is the answer (for the really brave ones ;-) ): http://www.gmat.unsw.edu.au/snap/public ... l1999b.pdf
tulloch
Re: Dual XGPS160
Post by tulloch »
Is this device available from a European supplier yet? Anyone got any idea if the data logging requires an iOS device or is there PC software available to download the logging data?
Re: Dual XGPS160
Mendelsohn (linked here: http://www.gps-laptimer.de/Compatibility.html) will be a supplier here in Europe. They do not have them on stock so far, but it will be a question of 1 or 2 weeks.
tulloch
Re: Dual XGPS160
Post by tulloch »
Thanks, Harry.
Re: Dual XGPS160
Harry wrote:... and here is the answer (for the really brave ones ;-) ): http://www.gmat.unsw.edu.au/snap/public ... l1999b.pdf
That paper refers to RTK, Real Time Kinematics. The position accuracy of RTK is on the order of two centimeters because the receivers use the signal phase from each satellite as well as the time information. Those receivers cost thousands of dollars and you need a base station receiver to determine local position and transmit the phase correction information to the mobile receivers. See for example the Racelogic VBOX DGNSS RTK Base Station ( http://www.velocitybox.co.uk/index.php/ ... n-rtk.html ). Inexpensive GPS receivers like the XGPS160 or the VBOX Sport aren't capable of RTK.
Re: Dual XGPS160
I used the Dual XGPS160 this weekend at an autocross and the effective update rate was 10 Hz in HLT. That's as good as I obtained with a VBOX Sport. With more satellites used, I think the altitude data was more accurate as well.
tulloch
Re: Dual XGPS160
Post by tulloch »
This has got some poor reviews on Amazon.com. Anyone else got one that can comment?
greatwhite
Re: Dual XGPS160
Post by greatwhite »
I just had one delivered today and plan to use it Saturday @Autoclub Speedway, I'll report back how it goes...
tulloch
Re: Dual XGPS160
Post by tulloch »
Thanks. Was about to order from Amazon when I noticed the U.S reviews.
Re: Dual XGPS160
Maybe gplracerx can comment on this. As far as I see the negative comments (there are very positive too) are from aviation users - which is probably a different game.
