iPhone 5 won't import exported cars or tracks
KrisS
Re: iPhone 5 won't import exported cars or tracks
Post by KrisS »
Having same issue with iOS 6 and Iphone 4. I udestarnd the workaround is to put file on dropbox and to import it from there ?
Ok. It worked through Dropbox
Yes, that's the current workaround. Version 17 has a workaround included: it is not using the .hvehl (= XML) format but instead uses a compressed format named .hvehz As mentioned above, this seems to be a problem in iOS.
