g-sensor not calibrated
Re: g-sensor not calibrated
None standard mounting position? See illustration #4 of LapTimer's Quick Reference. In addition, please make sure you have the Acceleration Calibration (LapTimer ‣ Administration ‣ Settings) set to Automatic Preset.
To repair existing recordings, select a lap with flipped acceleration from Lap List. Select Data Recordings / Preview ‣ Charts. Swipe to the G-G diagram. The blue buttons allow a number of loss free recalculations including lateral flips.
Mgbond
Post by Mgbond »
Thanks.
I want to use the phone in landscape as it gives a better view. Auto was already set. I have to use the front camera as the iPhone has the shutter issue.
In this case you can select the lateral flip option in Expert Settings. Or you flip data after the fact using the G-G chart button.
Mgbond
Post by Mgbond »
I have Grand Prix version. Is Expert next one up?
GrandPrix is the top edition. What I tried to reference is LapTimer ‣ Administration ‣ Settings ‣ Expert Settings ‣ Accelerator Tweaks / Reverse Lateral Acceleration.
Mgbond
Post by Mgbond »
Think I found it. Reverse Lat and reverse Long under expert Settings
Mgbond
Post by Mgbond »
Should I not reverse longitude also?
yes, true
Mgbond
Post by Mgbond »
Thanks. Looks like it’s working
