Very strange... I tested it again and it reports 8 POIs... LT does not cache the file, so it needs to be somewhere on the net... Can someone else reading this please test to download the Track Set? Thanks. A full reload forces a reload of all the track shape bitmaps, that will not cure the problem.
Maybe you kill LapTimer, start it, and try again? That's trial and error, sorry.
Croix-en-ternois, France
Re: Croix-en-ternois, France
Just reloaded Croix.
8 POI and corner names as per the map.
h
h
thank you, hms, at least now we know the problem is on my side
i have killed laptimer
i have done a complete reload of the track/add on list
I used 'croi' in the search field
I download the track
I get exactly the same result (attached screenshot)
I have tried manually searching the track in the list - still the same result
Things I could try:
-update ios (currently at 5.0, 5.1.1 is available)
-delete the app and redownload it from the app store, but that means losing all my stored laptimes
-if there is a cache server or something on my internet provider, I don't know how to turn that off
I don't know how close Harry is to finishing v16 - maybe I will do that when v16 comes out.
I have downloaded the iExplorer program - I thought maybe to try and save my databases - but it wont start up on my system. (outdated iMac running 10.5.8)
Harry, any other ideas ? I'm not really bothered by it - i'm not planning to go to croix-en-ternois for a while. As hms pointed out, everything is ok on your side.
Things I could try:
- IMG_0896.PNG (122.96 KiB) Viewed 2356 times
