Android 13 issues? Upgrade to GP edition and external BT connections
Re: Android 13 issues? Upgrade to GP edition and external BT connections
O.k. these are both BT SPP devices that need to be added using the BT+ button. I understand the app crashes when tapping it. Please let me know how you got the dialog "Bluetooth Verbindung wurde für LapTimer abgelehnt..." before?
Sideshow
Post by Sideshow »
Every time I start the app the BT warning message is shown!
Looks like this is a Samsung speciality (again). I have updated a Google Pixel to 13 and see no unexpected behavior. Neither do I get the Bluetooth alert on startup, nor does the app crash when pressing BT+. Instead, I get the list of paired BT devices listed and can select / connect afterwards.
Please make sure you have set the option to share app data with developers. This will submit crash logs I can investigate. You may want to force multiple crashes to make sure it is listed in the top. :-)
Please check:
Android Settings ‣ Apps ‣ LapTimer ‣ Permissions ‣ three dots in the top right ‣ All permissions ‣ Nearby devices
What do you see here, are "connect to paired BT devices" and "discover and pair nearby BT devices" listed? Going back one level, is the permission "Nearby devices permission" set to "Allow"?
Sideshow
Post by Sideshow »
Harry wrote: Wed Apr 05, 2023 11:55 am Please check:
Yes, this permission was always given. For testing I anyway allowed once all permissions, but made no difference.
HLT bluetooth issue v3.jpg (21.95 KiB) Viewed 6384 times
Sideshow
Post by Sideshow »
Harry wrote: Wed Apr 05, 2023 11:42 am Looks like this is a Samsung speciality (again). I have updated a Google Pixel to 13 and see no unexpected behavior. Neither do I get the Bluetooth alert on startup, nor does the app crash when pressing BT+. Instead, I get the list of paired BT devices listed and can select / connect afterwards.
Where is this option to share app data with devs?
Settings app ‣ Security & privacy ‣ More privacy settings ‣ Usage & diagnostics
Sideshow
Post by Sideshow »
Harry wrote: Wed Apr 05, 2023 12:20 pm Settings app ‣ Security & privacy ‣ More privacy settings ‣ Usage & diagnostics
Thanks! Ok, done. I forced multiple crashes again. Do you see them?
No crash logs on April 5th...
Sideshow
Post by Sideshow »
Hmm... I enabled the option and forced multiple crashes... :?
