Thank you Harry,
I will try again.
Unfortunately I have moved the files off the camera SD card.
GoPro Hero9 supported?
- snowfree52
- 10 or more Posts ★
Re: GoPro Hero9 supported?
Anyone else been able to get their GoPro 9 to work with HLT? I can get HLT to connect to the GoPro but its seems that the comment HLT is sending to the GoPro isn't doing anything. It either doesn't record anything or records a file that isn't usable.
Also, it seems the only way to connect to the GoPro is to open the quick app, connect to the GoPro from within the app, make sure you phone is now connected to the GoPro wifi and then go in into HLT. Is that what other people are doing to connect (I'm using a Samsung S20) and the latest beta version of HLT.
I work in IT myself and would happy to do some testing if it will help.
I have a new H9.
Use "Quik" to connect, then run HLT.
Manual start/finish recording buttons work OK in timer mode.
Video Recording seems to work OK - HLT knows there is an associated video.
The issue I see is the the video that has been recorded on the H9 shows as "offline" in HLT (laps and video lists).
HLT error: "Item cannot be displayed. The assets tracks were loaded, but could not be made playable".
If you try to preview the recoded video in "quik" it shows a thumbnail but cannot load the video.
I am also in IT and happy to help
- Fewer than 10 Posts
- Contact:
I have the same problem. GoPro 9 does not work with HLT. Does anyone know how to solve this? Tell me please.
