Support for GoPoint Tech BT1 OBD-II
F-Stop Junkie
Re: Support for GoPoint Tech BT1 OBD-II
Post by F-Stop Junkie »
Given how slow the DSC can be to kick in, I suspect the BMW bus is not very quick! :)
Understood on the integration, as I said, am happy to join in with any testing!
F-Stop Junkie
Received my BT1 last night. First problem I've got is that it doesn't seem to work! :lol:
Looks very nice and low key though. Got some troubleshooting to do, but I'm hopeful it's a good solution!
waddisme
Post by waddisme »
Getting ready to order, just not sure which is better - cabled or BT? I will be pairing with external GPS, so does cabled seem to be the best route?
Humanosaurus
Post by Humanosaurus »
I just ordered my BTS-1 as well, and am downloading LapTimer Pro as I type this. I'll be using it for autocross events with an iPod Touch 3g and either the Tom Tom mount, or the Dual Bluetooth GPS. I have both.
William
Bestlap
Post by Bestlap »
waddisme wrote:Getting ready to order, just not sure which is better - cabled or BT? I will be pairing with external GPS, so does cabled seem to be the best route?
If you use cabled one, you won't be able to charge iPhone while using LapTimer...
For sure cabled version is better in terms of resources, reactivity...
I was looking for the following cable : male dock port to (female dock port + USB).
This would allow us to use a dock device (the GL1 !) while charging the iPhone using the USB port !
But I did not find such a cable...
If you have it, please post the link ;)
Thank you very much !
Bestlap
Post by Bestlap »
I just found an adapter :
http://www.gearzap.com/cablejive-dockst ... -ipod.html
A cable would be better as we would not have 2 big dock connectors directly plugged on the iPhone, it's not so convenient and nice...
But the principle is here !
waddisme
Post by waddisme »
From the amazon website:
Technical Details
Directly connects OBD-II data to your iPhone & iPod Touch; patent-pending feature charges iPhone during operation.
With access to all OBD-II parameters, view, capture and CLEAR engine codes. View fuel consumption.
Works on all 1996+ OBD-II and EOBD vehicles with download of goLINK App.
With 1.5m cable connect your goLINK to the iPhone or iPod Touch without any dropped connections.
Official "Works with iPhone" product.
Bestlap
Post by Bestlap »
That's perfect, you're right !
I watched some videos on Youtube, we clearly see the charging logo on the top of the iPhone screen while GL1 is plugged !
Perfect !
So I think that between the BT1 and the GL1, I would choose the GL1 : you won't have to take care of your charger, GL1 will charge for you !
And cable is a better connexion than BlueTooth.
But but but...
I was thinking about another thing : choosing between a cabled OBD and a cabled GPS, I would prefer a cabled GPS.
GPS data is much more important than OBD data...
Imagine you buy a Bad-Elf GPS (a 10Hz cabled GPS), you would then have to choose a BT1...
Well, not so easy to choose if we look at all the necessary accessories !
Harry, perhaps you have an idea about the best configuration ever ?
I have my favorite here: Harry's Choice
The goPoint is not supported currently, I will add it once it works.
Bestlap
Post by Bestlap »
Thank you !
And if you would have to choose between a cabled GPS and a cabled OBD, which one would you prefer ?
Thx !
