manual start video
Re: manual start video
Found the problem. Actually not device specific, but depending on former video operations. Once a video recording using the internal cam has been performed, all recordings using "external cam only" mode will work. In case the internal video has not been used since the app start, "external cam only" skips the start.
Problem will be fixed for LapTimer v21.0.7. I plan to make it available soon.
Thanks again for the fast support.
arsprod
Post by arsprod »
Thank you! I'm fine using in dual cam mode!!
arsprod
Post by arsprod »
Just tested with the update - works like it should! You da man!!
