Questions on creating a track set...
Re: Questions on creating a track set...
The one on the video is so small you will not see the difference between a low accuracy and high accuracy recording. In LapTimer's Data Recordings - which features arbitrary zooming options, quality differs by GPS.
CWBOSS
What's mean ? "Triggers & POIs positioned"
Post by CWBOSS »
Hi harry~ :)
I am Always part of the problem is when you create a map
Lost a lot of documentation, but it does not make sense
Different starting and ending points map.
The height and direction of the difference is very much in the map.Is this a problem?
I really, really, really wonder " positioned "
Not sure I get the question. If you give a direction for a trigger, the real life driving direction needs to be within +- 90 degree - so really not a problem. Height is not relevant for trigger detection, so this is not critical - even for hill climbs or so.
