Session is recorded but no lap times
MiGorengNomNom
Re: Session is recorded but no lap times
Post by MiGorengNomNom »
I tried to add intro/extro time to the whole session with no luck. I could only add 1 second outro.
However, if I only select the hot laps to export, I can give 10s introduced and outro. Should I perform the export the second way?
Outro can be selected if footage exists beyond the lap range selected. It should be visualized by the oil strip pretty well? For the first (full) selection, lap 5 end exactly at the end of the video. I assume it is the cool down lap plus some pit recordings. ;-) You certainly can add an extro beyond "lap 5". Once you deselect lap 5, you can extend extro as shown in the second snapshot.
MiGorengNomNom
Monika wrote:Hi,
the Hidden Valley Track with the corrected direction of start/finish line is now available for download.
Please reload it in 'add-ons', update list with button at top right corner, search e.g. for ‚Hidden‘ and load the track.
To check your new track version, have a look at it in map view ->start/finish line has to be 90 degree to driving direction.
- Monika
Harry's LapTimer Team
Thanks, Monika! :)
Harry - Thanks for the help. It's making more sense now and I'll get to try it out again this weekend.
MiGorengNomNom
Track is working fine now! Thanks guys.
I had an issue with my final session though. The app encountered an error and didn't process the laps and mentioned something about it purging previous laps. Unfortunately, I deleted all those laps from the lap list. The weather was very cloudy and had patches of rain, could that pose a problem?
Also, I spun out during the qualifying session and the app stopped recording, then started recording when I got moving again and created a new lap/session.
