Page 2 of 2
Re: Lost ability to record video using GoPro Hero4
Posted: Sat Jul 09, 2016 4:53 am
by Draven
It doesn't work well with mine either. I have iPhone 6 using gps via Bluetooth and GoPro session . It is connected then drops. I forced the hero to RC from smart and thought that would do it but nope checked after next session and nothing... :(
Sent from my iPhone using Tapatalk
Posted: Sat Jul 09, 2016 7:24 am
The GoPro HERO4 Session is not compatible with GoPro's 3rd party interface. You need to operate it manually.
Posted: Sat Jul 09, 2016 7:38 am
As written somewhere above, the cycling indicator means LapTimer is looking for any multi cam devices. So even if a HERO is connected, it will continue to search for further MultiCam app instances (remember: one can connect an external cam and multiple MultiCam devices for iOS). This item is no problem.
LapTimer displays "HEROxy connected" once it sees a device at the well known IP address 10.5.5.9. However, in case communication is not working as expected, it will drop the connection and start over with searching.
This means there is some issue with communication. To trouble shoot, please reset the HERO. Make sure you can connect to it using the GoPro app next. In case this works, kill the GoPro app (double tap Home and swipe the GoPro app to the top). Any other app accessing the cam needs to be killed too.
Posted: Sat Jul 09, 2016 12:22 pm
by Draven
Thanks Harry! Damn GoPro for not integrating the api
Posted: Sun Jul 10, 2016 12:30 am
by Cloud9...68
Thanks, resetting the GoPro did the trick. Everything worked perfectly.
