The default gear ratios are from a Porsche 911 (997). As LapTimer uses a "best match" approach when calculating gears (instead of expecting a precise match between rpms expected for a certain gear and actual rpms measured), it often works fine out of the box. But I recommend to check the precise ratios and add them nevertheless.
Gear issues with OBD Kiwi 2
Re: Gear issues with OBD Kiwi 2
Thanks for your quick reply
