Automatic adapter problems
carramrod
Re: Automatic adapter problems
Post by carramrod »
Is there a way to break the Automatic authorization and re-authorize? Maybe that would help, since I'm having good luck with .108 right now (getting 11-13Hz update rate).
Not sure I understand... Any number of apps can authorise with the Automatic adapter. As Buddy and LapTimer use separate IDs now, there should be no interdependency any more.
carramrod
Post by carramrod »
Harry wrote:Not sure I understand... Any number of apps can authorise with the Automatic adapter. As Buddy and LapTimer use separate IDs now, there should be no interdependency any more.
De-authorize the app and then re-authorize the app.
Please check viewtopic.php?f=20&t=3143&p=16168#p16168 which is probably on the same issue.
