iPhone 6 Performance?
Re: iPhone 6 Performance?
DanMay wrote:Any update on better video when using the IPhone 6 ? This seems like a step backward rather than forward.
You should probably be directing your complaints to Apple, as it seems to be a problem with their firmware, not HLT. If the iPhone 6 can't be forced to turn off or lock autofocus and turn off video stabilization, there's nothing Harry can do about it from his end.
Unfortunately I guess Apple will always be upgrading the cameras for better photography and things like FaceTime etc. and probably never the type of fast motion / fixed focus and even global shutter we would like for onboard videos...there's simple too much Action cams out there becoming better, smaller and cheaper while smartphones are growing in size.
Addison1993
Post by Addison1993 »
I also want to know if the iPhone 6 GPS receiver still work at 1 Hz or at a higher rate.
There is not smartphone yet featuring more than 1 Hz for the builtin GPS. It is simply not necessary for "normal" smartphone users. Instead, a higher rate would consume more battery. Actually I have stopped checking for higher update rates in smartphones. ;-)
On the other hand, the iPhone6's GPS is a little more sensitive (compared to the 5S) again. I can hardly find any place in my dwelling and office not showing a GPS lock.
