Post Overlay Video Quality
- TooManyIDs
- 20 or more Posts ★★★
Re: Post Overlay Video Quality
I also had Anti-Shake turned on. Will try off next time.
Al
Apple iPhone 6 Plus (128GB)
Dual Electronics XGPS150A
PLX Kiwi 2
PLX Kiwi 2
- TooManyIDs
Yes, turn anti shake off if possible. For on track use, you will often get ugly effects...
- PitrsRS
Hi, i dont want to start new topic, so i will ask here.
Yesterday I tried for the first time On-board with Overlay. Recording is OK, clear picture, data saved. If I play recorded video without overlay in phone its everything ok, but if I apply overlay and then play video in phone, then picture has huge count of artefacts. Its strange, because if I copy overlayed video to PC/YouTube its everything OK
Where may be the problem?
In phone i´m using MX player for videos
Xperia P (LT22i)
Xperia P (LT22i)
- Screenshot_2014-06-25-21-45-36.png (79.82 KiB) Viewed 4981 times
2016 SEAT Leon CUPRA 290 ST
Looks like an incompatibility between the video format generated and your smartphone's video decoder. Does this happen for every overlay generated or is this an intermittent problem?
- PitrsRS
I´ve tried it 3 times on same video, but with diferent Overlay settings, result is same. It´s a minority problem for me, because in PC is everything ok, but it´s scare me when I saw it for first time.
Yes, it would be very difficult to fix that anyway. As video drivers are often OS version and manufacturer specific there is a certain chance it is going away with every Android update. Have you tried the different overlay quality settings? That is actually the only place the encoder level is influenced.
- PitrsRS
yes I tried it, I changed quality of overlay (video is in HD resolution), but it behaves the same way :/
