Android screen times out when setting autocross start/stop
Re: Android screen times out when setting autocross start/st
Add a trigger driving direction, that's much better than working with the corridor width. On the timeout: I have prolonged the time to timeout already - seems the requirements are even higher. Workaround: set the start trigger, walk *a bit*, set the finish line in some random place. Finish the AX. Now, walk to the finish line. Once you are there, drag the misplaced stop trigger to your current position using the Map View.
baggett67
Post by baggett67 »
I just came to report the same issue with the app timing out before I can finish walking the course. Fixing this will be a huge help to all the autocrossers.
vmbray
Post by vmbray »
Just noticed you fixed this! My phone quit updating and when I fixed it this was a cool surprise. Back at the track next month and noticed that you also have it sorted where the phone can be slept with the power button and it saves the start point. That is absolutely perfect, thanks!!!
vmbray
Post by vmbray »
Well my phone wasn't getting updates and I got that fixed and see that you fixed this! Thanks! The only thing I see now is that if you rotate the phone while its in autocross setup the dialog disappears and the setup is lost. Thanks again!
