Crash on export
spaRTan
Re: Crash on export
Post by spaRTan »
I just noticed that I cannot add new tracks any more.
When clicking a lap to download the POIs HLT just crashes.
So all iOS5-users NEED a downgrade as HLT isn't usable any more. :((
Re: Crash on export
I makes probably sense to clean up your main memory. I have an iPad1 here with LapTimer v17.4.3 installed and it loads the Tracks / Add-ons list as expected. The iPad has 256MB main memory only (same as the iPhone3GS) - which is the limiting factor. LapTimer requires between 25 and 50 MB memory at run time. Please please take care to remove apps running in background. To achieve that, you may reboot your device, or run a tool like "System Activity Monitor" available on AppStore for free. It claims memory so iOS kills background apps one by one.
Re: Crash on export
Harry wrote:That's an incompatibility issue with iOS5.1 iPads... I'm not sure I can fix but will try to. Please check the AppStore update descriptions for upcoming bug fix releases.
Btw. it seems the Export crash does not happen in 17.5 any more. Please check once it is available on AppStore.
spaRTan
Re: Crash on export
Post by spaRTan »
Harry wrote:
Harry wrote: Btw. it seems the Export crash does not happen in 17.5 any more. Please check once it is available on AppStore.
Yeehaa, I'll check it.
I've got a whole lot of laps from Most on my device that need some export... :)
