Page 2 of 2
Re: Android and Qstarz 818XT GPS not working
Posted: Wed Sep 11, 2013 5:43 pm
In case you are willing to do some more debugging, please go through the following steps:
- Start LapTimer and switch to Settings -> Expert Settings.
- Scroll to the Tracing options area, tick "Sensor Connection" and "Sensors".
- Turn on tracing by selecting "Logfile" from "Type".
- Go through the BT adding steps in Sensor List.
- Wait some seconds.
- Go back to Settings -> Expert Settings and select "Send Logfile (if available)"
- Send the log file mail generated to me
Posted: Wed Sep 11, 2013 9:44 pm
by StuartG
Done -- it should be on it's way to you. I tried selecting the BT GPS a couple of times, then sent the log.
-Stuart-
Posted: Tue Sep 17, 2013 9:16 pm
by StuartG
Did the log come through? I tried sending another (a few days ago) after you did not receive the original one.
Posted: Tue Sep 17, 2013 9:29 pm
No, I haven't received your logs. Please try to send it to yourself and forward it afterwards. Thanks.
Posted: Tue Sep 17, 2013 9:33 pm
by StuartG
Do I send the logs to myself by setting the "Default E-Mail" in the Export section of Expert Settings? Currently it is blank. Or is there a different procedure? Thanks,
-Stuart-
Posted: Tue Sep 17, 2013 9:35 pm
This is a convenience option only. In case you export data and logs
frequently, setting the default email address in LapTimer's Settings will make life easier. LapTimer will prepare the mail generated with this e-mail address. In case it is not set, you need to enter the e-mail address directly in your mail client every time you send a mail.
