- Start LapTimer and switch to Settings -> Expert Settings.
- Scroll to the Tracing options area, tick "Sensor Connection" and "Sensors".
- Turn on tracing by selecting "Logfile" from "Type".
- Go through the BT adding steps in Sensor List.
- Wait some seconds.
- Go back to Settings -> Expert Settings and select "Send Logfile (if available)"
- Send the log file mail generated to me
Android and Qstarz 818XT GPS not working
Re: Android and Qstarz 818XT GPS not working
In case you are willing to do some more debugging, please go through the following steps:
Done -- it should be on it's way to you. I tried selecting the BT GPS a couple of times, then sent the log.
-Stuart-
-Stuart-
Did the log come through? I tried sending another (a few days ago) after you did not receive the original one.
No, I haven't received your logs. Please try to send it to yourself and forward it afterwards. Thanks.
Do I send the logs to myself by setting the "Default E-Mail" in the Export section of Expert Settings? Currently it is blank. Or is there a different procedure? Thanks,
-Stuart-
-Stuart-
This is a convenience option only. In case you export data and logs
frequently, setting the default email address in LapTimer's Settings will make life easier. LapTimer will prepare the mail generated with this e-mail address. In case it is not set, you need to enter the e-mail address directly in your mail client every time you send a mail.
