Fiesta ST Technical Data
Re: Fiesta ST Technical Data
The numbers shown are the speed you would achieve with any of the gears reving the engine at max rpm. So especially for the highest gear the value will be a theoretical value. For a sports car using gear ranges to achieve best possible performance, values should be similar. For cars with an overdrive last gear, you will see a substantial difference between speed achievable in reality and in theory.
Or in other words: add 1000 HP on top and the values will be correct. :-D
