Dual XGPS150 Firmware
savowood
Post by savowood »
Did Dual go out of business? I'm trying to download the firmware to update the unit I just bought off Amazon, but whenever I go to the site, I get 403 (permission) errors. That's for the firmwarenew.html link, the index, and even the regular www.
If anyone has the firmware I can upload from my Mac, I'd appreciate it greatly.
Re: Dual XGPS150 Firmware
savowood
Post by savowood »
Interesting. Even after the upgrade, it still shows 0.0Hz.
This means you have no GPS reception. Please go outside and try again. LapTimer measures the number of useable / valid updates per second, not any technical frequency. Please watch the GPS view in addition - the Signal gadget (top left) in particular. You should see a blinking point here - red means invalid input, while blue is valid input.
Neoraptor
Post by Neoraptor »
There is also a utility from dualxgps on the Apple Store to check if the signal is here or not and see the status from the GPS ;)
>> https://itunes.apple.com/fr/app/bluetoo ... 61436?mt=8
savowood
Post by savowood »
The site is working again, and I have the firmware updated. I used it last night on my flight to see our altitude and speed. I think there must have either been an error, or possibly a very heavy tailwind. It was showing over 600 mph SOG. The last time I checked, a 737 topped out about the mid-500 range.
hms
Post by hms »
Isn't there something about standard GPS only working properly up to a certain altitude/speed?
I never manage to get my MX5 offf the ground!
From Dual FAQ page
I’m a pilot. Can I use the GPS Receiver in the cockpit?
Yes. The GPS Receiver works with popular electronic flight bag apps including EFB, ForeFlight, and WingX Pro. If you are a commercial or corporate pilot, please contact customer support for some helpful tips on using the XGPS150 in aircraft with heated windshields and at high cruising altitudes.
H
