Best Virtual Lap as Reference
hapnermw
Post by hapnermw »
When working on improving driving technique, it is useful to work on one split at a time. You might want to spend the first few laps of a run working on one split and then switch to another split.
If you had the ability to select best virtual lap as the reference lap, this would be easy because it contains all your best splits. You would want the split times for this lap to be fixed at the start of a run so that the reference split times were not changing within the run. On a subsequent run, you would start again with the current best virtual lap.
lisocayman
Post by lisocayman »
Traqmate has an automatic feature to create a theoretical best lap TBL for a given session. This is dynamically created based on segment times. It's a great feature and something I'd like to see in HLT
You have that already. :-)
You can see the virtual best by selecting any lap of your session, pressing Lap Time in the Results section and get a picture like the one attached. The blue bar in the right is the virtual best made up from best sector times (red).
MStephens
Re: Best Virtual Lap as Reference
Post by MStephens »
I wish there were a way to show the virtual best lap as a reference lap in the Charts display (Speed @ Distance).
Harry is there any way to incorporate that into the app?
Added to the list...
