I have an iPhone 4, and the latest available version of HLT. I also have an external GPS device (XGPS150) and get ODB data using the PLX Devices product. Both of these devices seem to be functioning correctly. The XGPS150 connects via bluetooth just fine, and the iPhone connects to the PLXDevices wireless network. In HLT, the software shows that both devices are working just fine.
I defined myself as the driver, loaded the data for Lime Rock Park, selected my car, and then hit "Start Driving". The timer screen is then displayed... and NOTHING happens after that. I ran all 4 sessions, and must have run 60-70 laps, but never did HLT record a single thing.
After the 1st session, I tried changing the POI Detection setting to "Wide", with the same results.
After the 2nd session, I tried reloading the data for Lime Rock Park (I had previously done so before arriving at the track), but still had the same results.
After the 3rd session, I noticed that I had "Online Racing" -> "Publish" set to "Lapping", so I set it to "Never", but *STILL* got no data. I was wondering if the inability to contact Harry's server might have caused a problem.
I could not find anything in the HLT interface to indicate why it wasn't working. If you look at the LRP GPS data in the map, it sure looks like those data points are correct.
How can I gather additional diagnostics to figure out why it wasn't working?
What else can I try changing to possibly get this to work? Perhaps NOT use the external GPS device? Not connect to the PLX device? Both of those options occurred to me after the day was over, and I want to come up with a plan before I head to NJ later this month. I have 8 chances (4 sessions on 2 tracks over 2 days) to try to get some valid data, so there's only so many things I can try (my track time is VERY valuable to me, so I'm not going to ruin a session by pitting 5 times to tweak HLT -- each session gets one chance at each attempt
Lime Rock Park is one of the most popular road courses in the NE part of the US, and I can't believe I'm the first person to try to use HLT there, so I am at a loss to explain why it didn't record anything.
