When in the list view for laps you can select options -> edit, from here you can delete items which is great but if you delete the first item it drops you out of that view making it difficult to remove multiple items.
The current workaround is to delete items from the bottom up, which doesn't drop you out.
Maintain list view on first lap delete
cars4enjoying
Re: Maintain list view on first lap delete
When going to edit mode in Lap List, tap the red circle in the front of a row and the Delete button to the right afterwards. This should make Lap List remove that lap but stay in edit mode for the next delete.
A workaround for multiple deletes is grouping: select for example Session and select a session of laps to delete. In the sub list shown, you will find a cross / delete item in the bottom. It will remove all laps of the session.
cars4enjoying
Yer I tried that but it still drops you out of the list if its the first item. I case it makes any difference I was in day mode, within a specific day, tried it a few times same behaviour before I realised that deleting from the bottom worked as expected.
