Hallo everybody,
I'm new here and new with HLT. Searched the forum but couldn't find an answer.
I recently bought a "new" car with honda conversion and will be doing some trackdays with it.
It comes with this android radio: https://www.joyingauto.eu/joying-new-6- ... tereo.html
I will be using it to read my doctronic info as the ECU has a WIFI module using the Droidash-K app.
A couple of questions.
First one. As the radio has a split screen option I was thinking of using HLT as well as the Droiddash-K app. The stereo comes with it's own GPS antenna (see picture). Will this be sufficient for a good readout of HLT.
Second one: is there a possibility to get the ECU info (like rpm, gear etc.) in HLT.
Thanks in advance
Droidash-K and GPS module
Ginthahouse
- image.png (298.83 KiB) Viewed 1156 times
Re: Droidash-K and GPS module
I can't answer, you need to test this yourself. It depends on the way Android is implemented on this device. In case the GPS data is properly injected into Android, LapTimer will use it automatically. For OBD I doubt it will work. Except for the OBDLink SX device, all integration is using BT SPP or BT LE.
You can use Harry's GPS/OBD Buddy to test this too.
