Tonwon BTLE OBD not working
phips2996
Post by phips2996 »
I've trouble getting HLE working with the Tonwon T2 BTLE 4.0. As you can see in the screenshots it is connected but no update rate (Hz) is shown. The expert settings are set back to default (UUIDs). What am I doing wrong?
Re: Tonwon BTLE OBD not working
This means communication between app and adapter is working, but the negotiation between adapter and car bus failed. It may be necessary to select the Default Bus Protocol in LapTimer's Expert Setting. This will make LapTimer ask the adapter to use a certain protocol (like CAN 11/500) instead of asking the adapter to doo the negotiation on its own.
See viewtopic.php?f=39&t=1500 for more tweaks.
