Laptimer will not open
KingKong
Post by KingKong »
I have HLT Grandprix on Note 3 - Android 5. Been using for few years no issues. Just did update now the app will not open . Keep getting error message "Unfortunately, Lap Timer as stopped"
Uninstalled, reinstalled, restart etc. will not open.
Any help appreciated.
Sprocket
Re: Laptimer will not open
Post by Sprocket »
I have the same problem, curious if anyone has a solution?
Sprocket wrote: Wed May 20, 2020 4:40 pm I have the same problem, curious if anyone has a solution?
Are you on Android 5 and have you reinstalled the app too? Please keep in mind uninstalling the app will purge all recordings.
I will run a regression test for Android 5.0.1 before releasing v24.
KingKong
Post by KingKong »
Harry wrote: Wed May 20, 2020 5:08 pm
Yes, I reinstalled. Yeah found that out after I notice the storage was significantly lower :(
Wanted the data more than the recordings.
KingKong
Post by KingKong »
Any update?
Release v24 is scheduled sometimes in June. Thanks for your patience.
