Hi
Don’t know if I’m being stupid? But this tool does not seem to do anything! When I drag the PUSH files over to the CDF circle they just vanish and nothing happens.
Does anybody have any other ideas on how to get this PUSH smartgauge to work??
PUSH SmartGauge
Re: PUSH SmartGauge
The online tool itself works for me but when i try to open it on my phone there’s no longer an option to open with Harry’s lap timer
Re: PUSH SmartGauge
What is the file's name, from where do you try to open it, are you on Android or iOS, and which version?Craig86 wrote: Fri Mar 27, 2020 9:22 pm The online tool itself works for me but when i try to open it on my phone there’s no longer an option to open with Harry’s lap timer
Re: PUSH SmartGauge
The file name is 038-000.gpx which was generated by the website. I tried to open it from my gmail. I'm usingHarry wrote: Fri Mar 27, 2020 10:02 pm
ios 13
Re: PUSH SmartGauge
This has become a bit wired after late iOS changes. When touching an GPX file and you do not get the dialog to select actions, try the distribute button appearing somewhere (depends on the app, I do not use Gmail on iOS). Once you are in the dialog allowing the selection of actions to apply (like Mail, Dropbox, Copy etc) and you do not see “Copy to LapTimer”, select the More button to find it.
Re: PUSH SmartGauge
That worked!! Thank you very much
