GoPro Hero 7 Compatibility
Re: GoPro Hero 7 Compatibility
I cannot reproduce the effect. Probably some processing overload etc. One thing which might influence behavior when using the manual timing functions: these work well with a good GPS reception only currently. This is actually a limitation that will go away for LapTimer v23. For now, please check if you see the same delay when outside.
PitrsRS
Post by PitrsRS »
Ok, thanks for the advice. I'll try it in next few days
2016 SEAT Leon CUPRA 290 ST
HLT Grand Prix (Android) + OBDLink LX BT + XGPS160 + GoPro 7 Black
PitrsRS
Post by PitrsRS »
Hi Harry, I want to ask. Does HLT make any changes in camera settings when its connected? Because I usualy using 2,7K and after playing with GP7 and HLT together I noticed changed settings in camera to 1080p, changed ISO etc.
See video documentation on www.gps-laptimer.de/documentation.
You can select the resolution selected using MultiCam Preset setting:
Master ‣ GoPro video used as Master, resolution set to 1080
PiP ‣ GoPro video used as PiP, resolution set to 720
None ‣ GoPro video used as Master, resolution unchanged
PitrsRS
Post by PitrsRS »
Ah, ok that explaining everything ;)
