OBDII Throttle position display meter
I've been playing with HLT with my iPhone 4S, GoPoint BT1 OBDII sender, and a 2010 VW GTI. One thing i've notice is that it seems like the green bar graph of the throttle position seems to go to max very easily. For example at around 2/3rd throttle it shows a full green bar. I know its not fully throttled because i can hold it there and then push the pedal down harder and the car will go faster. I see in the data logs that the throttle position value is a decimal between 0 and 1 so its not like there is a random maximum value that must be calibrated, etc. Or is that done behind the scenes before the data log is created? Any ideas?
Thanks a lot,
Dan
Thanks a lot,
Dan
Re: OBDII Throttle position display meter
OBD defines throttle comes in at values between 0 and 255 (mapped to 0 to 100% or 0.0 to 1.0 in LapTimer). Problem is cars do not use the defined range and instead deliver e.g. values between 4 and 120... This is the reason LapTimer auto calibrates min and max values: It initially sets a low max expectation (need to check the sources for the exact value) which is treated to be 100%. In case a value higher than the expected max value is received, the 100% calibration is shifted up. This means you will have your throttle calibrated once you have fully pressed the pedal once - which is an easy task on track
Ah nice. i wondered that and definitely saw an improvement after i floored it once. I still feel like i was saturating a bit early, but i'll use it some more and see.
Just being curious:
Does the throttle PID really show the actual pedal position or the throttle body position / engine load. With all that drive by wire stuff the actual pedal position doesn't mean the engine is doing the same
The throttle PID 0x0111 delivers your pedal position + what engine control believes is necessary. You can switch to pedal position PIDs in LapTimer's expert settings (0x0147 to 0x014B) if you want. Please check what you car has available first (Sensor List -> touch row showing your active OBD - so you need to do this with your iPhone connected to your OBD with the engine on). A description of the different PIDs is available here: http://en.wikipedia.org/wiki/OBD-II_PIDs
So I can do this for many of the PID if I have the correct ID for the PID. For instance;Harry wrote: ↑Thu Apr 25, 2013 8:11 am The throttle PID 0x0111 delivers your pedal position + what engine control believes is necessary. You can switch to pedal position PIDs in LapTimer's expert settings (0x0147 to 0x014B) if you want. Please check what you car has available first (Sensor List -> touch row showing your active OBD - so you need to do this with your iPhone connected to your OBD with the engine on). A description of the different PIDs is available here: http://en.wikipedia.org/wiki/OBD-II_PIDs
Throttle ID: 0x140
Brake Pressure ID: 0xD1
Oil Temp ID: 2101
To not mislead others: the PIDs named are incomplete or not correct. 0x140 will be interpreted as mode 1, PID 0x40 - which is the channel documenting which of the mode 1 PIDs 0x41 to 0x60 are available. So strictly speaking, it is no PID at all. The alternative throttle PIDs are mode 1 0x47 to 0x4B as written above. These are all standard PIDs. 0xD1 is no standard PID and at least incomplete, 2101 is interpreted hex (i.e. should be 0x2101 when using the same syntax as the other PIDs) and will retrieve the full array of custom PIDs for Toyota, Subaru, Scion makes.
I'm trying to figure out how to set the information in Harry's for throttle and brake for my Subaru BRZ (2013). I've found PID information for a number of items, I just can't seem to find (in app, in PDF doc or in forum) how to set the proper information. Can someone share where I can find a tutorial?
- PitrsRS
I usually used for throttle PID D, but after last update it doesn't work any more :-\
2016 SEAT Leon CUPRA 290 ST
Not related to the last version. I know new versions are often suspects to all kinds of issues, but this is some other configuration issue.
