Laps not recorded
Oswald
Laps not recorded
Post by Oswald »
Laps are only recorded when I use video.
When not, nothing is recorded.
Re: Laps not recorded
No, this will be some coincidence with a different problem. LapTimer production versions are regression tested without video before being released. It is possible detection doesn't trigger because of missing / bad GPS or missing track sets, or some other reason, but video is always an add-on.
NB: Recent LapTimer versions 22.1.x did not trigger laps for s/f lines going N/S or W/E plus some other rare scenarios. This issues will (hopefully) be fixed with 22.1.2. The current 22.1.1 should work a lot better than 22.1.0 already.
In case you are sure you used 22.1.1, please let me know which track set you used when running into the problem described.
Oswald
Post by Oswald »
I am using v22.1.2.
It happend at Clastres and Abbeville. Only the laps where I use video are recorded.
Just to clarify: you are using 22.1.2 now. As it has been released yesterday (Android), you will have used 21.1.0 or 21.1.1 for the date reported initially.
Oswald
Post by Oswald »
Now it works perfect.
