Right now it seems that the lap comparisons show accumulated timing difference. I would like to be able to see the difference for the data I am zoomed to (eg. what is visible) starting at zero on the left most data point.
Thanks for your consideration!
Zero based Diagram timing differential
Re: Zero based Diagram timing differential
Yes, good point, this will probably be better for analysis...
