LapTimer v22 beta and early access program
Post by Harry » Fri Apr 27, 2018 6:37 pm
Dear friends of LapTimer!
We will start LapTimer v22 beta testing shortly. :geek:
Applications for participation are triggered from within LapTimer.
Please follow these steps:
  1. Start LapTimer on your smartphone
  2. Follow Administration ‣ Add-ons
  3. In case you do not see "LapTimer v22 Beta" in the top of the list, press "Refresh"
  4. Select "LapTimer v22 Beta" and "Request"
  5. Fill in all sections marked using ALL UPPER CASE and send the mail to me
In case the application is incomplete, I will come back. Otherwise please wait for instructions to download the beta app. I plan to have a first version available as soon as possible. Please do not poll for the precise date of availability. ;-)
Before applying, please make sure:
  • You love beta testing and early access programs!
  • Your are willing to work with incomplete and not super stable software.
  • You create a backup of your v21 lap history front up.
And here is the list of changes planned for LapTimer v22:
Code: Select all
Sensor Handling
Variable recording rates using splined interpolation (e.g. 5 or 10 Hz)
Massive changes for engine sensors
	- Full brake pressure support
	- Refactored existing code to allow flexible configuration
	- Automatic bus type detection, all optimizations are done automatically
	- Support for custom PIDs, formula based evaluation
	- Added support for physical ECU addressing, major speed improvement
	- Improved OBD debugging support
	- Further update rate improvements
	- End to end sensor data queuing minimizing real time effects
	- Support for extended channels: gear, odometer, brake pressure, individual
	  wheel speed, steering wheel angle and rate - requires scripting or
	  custom PIDs
Support for ReDrive sensor
Disabled generic sensor configuration
User Interface
- User Interface refinements
- Hall of Fame filtering by Group
- Edmunds support removed (discontinued by Edmunds)
Video
- Added brake pressure to video overlays
Accessories
- Update to watchOS 3.0 (no functional changes) [iOS]
- Revived MultiCam app - use old iOS devices as second cam
- Reworked MultiCam app communication [open]
- Added support for iOS MultiCam app [Android] [open]
- Improved video download reporting from HERO cams [open]
Special fixes
- Fixed "decoder busy" issue [iOS]
- Fixed issue with spaces in video file names [Android]
Optimizations, fixes, and minor improvements all over the place.
I'm looking forward to your applications!
lisocayman
Re: LapTimer v22 beta and early access program
Post by lisocayman » Thu May 31, 2018 4:30 pm
Question will brake pressure be available via OBDii Bluetooth sensors? If not curious how to obtain this? I stopped using HLT for a while but I’m back! Unfortunately my old BT1 isn’t working correctly with HLT so I’m thinking of getting a new only likely the kiwi3 if that’s still the recommended one.
I’m ideally looking for throttle, brake pressure and wheel speed/slip etc for a 991.2 GT3.
Post by Harry » Thu May 31, 2018 5:12 pm
In case the BT1 doesn’t work, it should be a hardware or configuration issue. The BT1 is supported for the latest LapTimer version.
Brake pressure is not a standard OBD PID. This means one needs to have insights into car specific custom PIDs, and configure it in LapTimer. Support for this is available in v32. In case the parameter is not available, LapTimer calculates braking pressure from longitudinal acceleration (taking air resistance into account). The later is working pretty well.
lisocayman
Post by lisocayman » Thu May 31, 2018 7:24 pm
The interpolated brake pressure sounds cool (nice work). I assume we need to wait for this in v22 as I don’t see this in 21.
Post by Harry » Fri Jun 01, 2018 6:49 am
It seems there are problems with the BT1... Please see viewtopic.php?f=42&t=4899&p=24421#p24420. I’d suggest to contact GoPoint on what is required to get rid of connection issues.
anthonymckay
Post by anthonymckay » Mon Jun 04, 2018 5:48 pm
Hi Harry, will there be support for the Hero 6 in the v22 beta?
Post by Harry » Tue Jun 05, 2018 2:37 pm
You can use the HERO6 BE using the HERO5 BE setting in LapTimer's v21 production version already.
Sideshow
Post by Sideshow » Fri Jun 29, 2018 7:14 pm
I noticed that I also have the issue with missing gforce acceleration data. Therefore applied for v22 beta.
ClaudeHetu
Post by ClaudeHetu » Thu Jul 05, 2018 5:19 pm
Hi Harry, I did last-week the request for the v22 beta, but I didn't get any e-mail, so Is it possible to get the Beta, I had custum OBD connection on BLE that had loggin problem with V21. I have a track event next week-end, It will be nice to test it with V22
Claude
llan981
Post by llan981 » Fri Jul 13, 2018 7:29 pm
When is V22 Product general availability release scheduled?
