config: iPhone 6, Bad Elf Lightning GPS, Kiwi ODB II Adapater, Go Pro Hero+ Camera on WiFi, connected to a 981 Cayman S
- Set the software up for my track
Set video mode for external camera only and ensure it's linked
See laptimer is all set to go on status at the top.
Ran my laps, validated I have data, and videos are recorded
Put the Micro SD from GoPro into an SD Adapter then when the pop-up occured transferred all videos to the iPhone
(This is where issue #1 occured, the videos came in with the time shifted (As if the GoPro is in a different time-zone, although the clock on the GoPro is correct, and there's no timezone setting I can find)
Back to lap timer, looked at my sessions (I'd really like this to be a view I could make default) and picked the session I wanted to associate
Tapped on the empty video square
This is where I get confused the documentation says to click re-link, but there's no re-link button in this dialog, at the bottom of the screen is a Blue camera with a dark grey camera sort of shadowed behind it, clicking this brings up the video-list, and tapping on a video here will bring up a dialog that has a "Re-link" button on it, so I'm thinking I got this right
Now I've got an overlay but there's a problem with it- The video lags behind the data, by the end of the lap it's significant, you can watch the g-bubble and the steering wheel, or the track map and it's clear that these are not correct
The next thing I did was try to export some video even though it was off, as I figured if I could view it on a larger screen I might be able to see the laptimer on my dash (it's in shot) and see how far off it is to help me figure out the correction. When I do this however it asks me which lap numbers to export in the first dialog, however those lap numbers aren't displayed on my laps when I'm picking them to view to begin with. In addition it doesn't seem to allow me to scroll left or right when I touch the arrows to pick more laps. I have more laps in the session then are shown there but I can't export the entire session.
Any help anyone can give me here would be greatly appreciated. These are the last issues I'm having now that I've gotten the GoPro more stable, and just working better.
thank you
