Hi All,
I accidentally pushed "Purge GPS" for one lap and the data is gone.
Anyway to add it back to this lap?
It did not affect the rest of the session.
Adam
add GPS data to Lap
- immerlacken
Re: add GPS data to Lap
Usually not, at least not if you have no backup...
You can try the following (in case you are adventurous):
- Export your current database to .hlptrl. Use Administration ‣ Databases ‣ Backup for this.
- In the list if automatic backups in the bottom of Databases, check if you see a recent version which includes the lap with data purged.
- Swipe / long press this backup and use Restore to make it the current database.
- In case this database includes the lap, export this single lap to .hlprl from Lap List ‣ this lap.
- Go back to Databases and return to the database with purged lap (shown is Inactivated Database): use Restore
- Import the single lap you exposed above.
