Invalid Master Video Error
Megator
Re: Invalid Master Video Error
Post by Megator »
Solved! Removing the spaces did the trick.
kd1irk
Post by kd1irk »
I'm having the same issue. Checked this and the other linked thread. Still at a loss. I tried to relink several times.
Please clarify what the problem is.
kd1irk
Post by kd1irk »
I'm getting Invalid Master Video Error when trying to link a video to a lap.
I followed the instructions in the FAQ and other as listed in this post.
I've tried multiple videos and multiple laps.
I'll upload a screen shot of the actual error. I thought I uploaded it with the previous post...my apologies.
kd1irk
Post by kd1irk »
Heres one of the errors...
The snapshots show Video List and Video Details, but not Lap Details. That's the dialog a Re-Link should be started from.
kd1irk
Post by kd1irk »
Lap detail
I rechecked the code what could make LapTimer display a video thumbnail with type "Raw Video" in Lap Details and not reveal the "Export" button at the same time (looks like you have "Play" only?). One option is you do not have a LapTimer edition with overlaying enabled (i.e. Rookie), the other is some inconsistency in video type (Overlaid / Raw) in LapTimer's database. The later can happen if videos are attached / overlaid / detached etc. in a certain order (I'd like to understand to close that door). To fix this, memorize the sync offset information shown Video Details first. Then, return to Lap Details and remove the video from the lap (long press the video thumbnail in Lap Details). When prompted, do not delete the video physically. Then, add the video again (using Add Video from the action menu).
kd1irk
Post by kd1irk »
Harry wrote:Hi,
You nailed it right there. I was running Rookie vs. I upgraded and now it works great. Thank you!!!
