Firmware 2.11.0 for RaceCapture/Track
Has thanked: 11 times
Been thanked: 30 times
Re: Firmware 2.11.0 for RaceCapture/Track
Postby gplracerx » Wed Apr 26, 2017 9:33 pm
Firmware 2.11.0 allows CAN channels on the RaceCapture/Track without Lua scripting. Will HLT be able to see that data once I can configure a CAN channel correctly? The update rate with CAN should be much faster than for OBDII, even with parallel requests.
Has thanked: 97 times
Been thanked: 354 times
Postby Harry » Wed Apr 26, 2017 9:38 pm
Yes, LapTimer reads the channels listed in viewtopic.php?f=39&t=4244
The source (direct CAN, analog / digits / OBD) is not relevant, so you should be able to benefit from faster CAN.
Postby gplracerx » Fri May 12, 2017 9:47 pm
It worked for RPM after I remembered to turn on CAN channels on the device. I'm hoping to replace all the frequent OBDII requests with CAN channels.
Postby gplracerx » Sat May 13, 2017 11:50 pm
I've emailed the hlptrlz file from today's autocross. As you can see, the heading data has a huge range, up to 6553.5 degrees.
Postby Harry » Sun May 14, 2017 3:59 pm
I'll check, please give some days, I'm traveling.
Postby gplracerx » Sun May 14, 2017 4:13 pm
No rush. You should see what it does to the dynamic map when viewing a video. it spins like a top.
Postby gplracerx » Sun May 14, 2017 10:58 pm
If it helps any, I don't think it's smoothing. It appears to go bad when the heading decreases below zero. It should go to 360. Instead it goes to above 6500. Needless to say, it takes a second or two to recover from that. There's also still a problem with duplicate lines.
MrBlah
Been thanked: 4 times
Postby MrBlah » Sat May 20, 2017 7:17 pm
Was there a change to the mk2 code already? I'm at vir and it's totally not working
Postby gplracerx » Sat May 20, 2017 9:31 pm
MrBlah wrote:Was there a change to the mk2 code already? I'm at vir and it's totally not working
Do you have the Wi-Fi module? It won't work with HLT over Bluetooth. You also can't control a GoPro at the same time.
What firmware version do you have? The latest is 2.11.0 You also have to be sure you download the correct firmware for your device and you need a PC to load it. Mac's don't seem to work.
My RaceCapture/Track with 2.11.0 worked just fine, other than the direction data in HLT, at an autocross last weekend.
MrBlah
Postby MrBlah » Sat May 20, 2017 11:18 pm
Bluetooth it's giving hlt garbage data never triggers a lap and says the accuracy is 600 feet
I did not update the firmware nor could I here at the track, I had everything working with the beta
Return to “Accessories”
Who is online
Users browsing this forum: No registered users and 2 guests
