Deleting Lap within Session
llan981
Post by llan981 »
If I have a 10 lap session, and two laps were joint due to bad. GPS split. and cannotdo a verify lap and split .
1} should I import my go pro video and add it to the session and then delete the two laps and then do overlay or
2)) delete the two laps and then import the go Pro video and then do overlay.
Do both work?
Re: Deleting Lap within Session
Both work but the later will require you to run two "half Session" overlays. LapTimer will consider laps before and after the deleted double laps seperate sessions.
In case Verify Lap doesn't work, please enlarge the Wide Corridor from 40 to e.g. 100 meters temporarily. This should catch the line...
