As a test when not driving, if you turn your phone 90 degrees left or right, the G-Force meter will read precisely 1.0 proving the phone's accelerometer is very accurate for that static situation.
When my vehicle is parked on a side-slope that approximates my vehicle's maximum body roll, the G-Force meter is somewhere between .1 and .2 G. So when the G-Force graphic shows 1.1G on a video, is it safe to assume the actual G's was about .8 or .9 because of the effect of body roll on the measurement ?
If that is true, and you are looking for something to do, maximum body roll could be added to the Vehicle description and be a progressive correction factor added to the G-Force graphic
