Sometimes no moving Points in online View
Hi at all,
I´ve a problem on online view. Sometimes I see no moving points on track on my Android 4.4 with Laptimer Version 18.3 Petrolhead. It is conected and says X drivers online. I see the Hall of Fame with actualisations, but no points on track. At the same time there are points on track, if I look with Firefox from a PC online.
cheers
Marcel
cheers
Marcel
Re: Sometimes no moving Points in online View
Strange... Do you see a track shape? Have you selected the same track like that watched from your PC?
Both yes... It's Nordschleife btg at the moment. Now no points and döttinger Höhe is one line. I mean döttinger Höhe is cutted from gantry to bridge, if I see points.
You will always see drivers using the track set selected. So if you select another NOS config, BTG drivers will be invisible... But when selecting the track, you should see the actual number of active drivers (that should appear as dots)...
I tried to append a screenshot, but all I can create is to big for this forum. NOS BTG is selected for Lokal track and online.
Second try. Thats, what I see:
I tried with my second Android (Galaxy S5), too. But its the same. No points on every active track.
Or do I have a problem with on license on two devices (Same google account) now?
cheers and thanks Marcel
- 2015-05-31 13.15.28.jpg (16.72 KiB) Viewed 3070 times
Yes, I raised the quota, it has been ridiculous small... The second phone should not be an issue.
I have organized a Droid and checked. It seems to be a bug in the current version. I will try to fix it fast and come back.
Oh god, it seems to be not my fault
So I can calm down...
Thanks a Lot!!!
Nice rest of weekend!
Marcel
Thanks a Lot!!!
Marcel
