Setting Target Sector Times
Aj2923
Post by Aj2923 »
Is there a way I can make a fake lap or insert target sector times.
Id like to be given a + vs my target sector. If i go below this sector time then this is again set as the new target.
Would be useful for qualifying situations/race pacing.
Re: Setting Target Sector Times
Have you considered using predictive lap timing instead of sector optimization? LapTimer does not only give you the gap to a reference (e.g. best) but tells you if the gap is reduced or enlarged currently. Check the Timer View for this feature.
Here is the description on the Timer View modes: https://www.facebook.com/media/set/?set ... 618&type=3
