How to import Car definition from HLT to GPS Buddy ?
This forum covers all topics on Harry's GPS Buddy
KrisS
Post by KrisS » Tue Jan 13, 2015 9:38 pm
Hello upgraded to latest version of GPS buddy today and bought satelite and OBD info features. Now for the last one (OBD) to work properly I need the car data defined. I am able to export the car def from HLT rto my mail but how to copy/import it to GPS buddy ? When I press the attachment it allows to choose mail, dropbox and HLT to open it. No GPS Buddy on the list. Any hint / info how to do it ?
regards
K
Re: How to import Car definition from HLT to GPS Buddy ?
Post by Harry » Tue Jan 13, 2015 9:55 pm
GPS Buddy is not registered for any file type, that's the reason it isn't offered to open the .hvehl file. This mean you need to enter the data manually...
Post by gplracerx » Tue Jan 13, 2015 10:39 pm
The new lookup feature in GPS Buddy helps a lot with vehicle data.
Post by Harry » Tue Jan 13, 2015 10:52 pm
If Edmunds would add gear ratios, I'd really love them :-)
KrisS
Post by KrisS » Wed Jan 14, 2015 9:32 am
I entered car data manualy. In lookup there is no Focus RS Mk2 btw.
Post by Harry » Wed Jan 14, 2015 9:34 am
Edmunds provided models sold in the US market only. Not sure the MK2 is one of these?
KrisS
Post by KrisS » Wed Jan 14, 2015 10:03 am
Focus RS Mk2 was not fords' "Global model" and was marketed outside US. The scock model data are follwoing:
- Turbocharged / RON 95/98 fuel
-Displacement (cc) 2522
- Max power ISO PS (kW) At engine speed 6500 (rpm) 305 PS (224kW)
- Max torque (ISO Nm) At engine speed 2300 – 4500 (rpm) 440 Nm
- Max engine speed (rpm) 7050 transient (3 seconds) with continuous at 6500
- Engine speed at max speed 6175 (rpm)
- Fuel Tank (litres) 62
TRANSMISSION
Transmission type Manual 6-speed, synchromesh on all ratios including reverse
Gear ratios
6th 0.7
5th 0.868
4th 1.088
3rd 1.433
2nd 2.05
1st 3.385
Reverse 3.231
Final Drive 4.00
- Standard wheel size (in) 19x8.5 Tyres Continental 235/35 R 19
- Overall length (mm) 4402
- Overall width, excl. mirrors (mm) 1842
- Overall height (mm) 1497
- Wheelbase (mm) 2640
- Basic kerb (kg) 1467
- Gross vehicle mass (kg) 1860
- Payload (kg) 543
Mine is a little bit modified I can send the export file from HLT if required
