The varying OBD rate is most probably due to a system overload. Due to the request / reply pattern, any lag in processing on the LapTimer side has an impact on the update rate. I have a test version for Android that dedicates a full thread just to OBD processing and this version delivers a more constant rate (i.e. no exceptional lags). This version is not yet stable however, and will require quite some effort to cope with synchronizing the parallel activities.gplracerx wrote:The 8-9 Hz with the Kiwi wasn't stable at an actual event. I had rates all over the map. In one case I was seeing 40Hz, but no actual data. Killing the app and restarting fixed that. Unfortunately, I didn't have time to create a log at the event. I'll see if I can duplicate the problem when I'm not under time pressure and create a log file. But it's going to be a week or more before I'll have the time.
In case you are still using an iPod plus a 10 Hz GPS and this high frequency OBD approach, it is likely it is time for the next gadget generation.
