I currently have an iPhone 4S 16GB, but will be switching to a Galaxy S5 within the next couple days. I see I can get a 30% transfer discount, which is nice. Thank you. Last week I used my Grand Prix LapTimer and recorded the video on my iPhone as well as on a GoPro 3 white. I just read today that I should have recorded in SD mode and then deleted the video so I could have done that with every session, instead of just the one 40 minute session I could hold on my phone.
I still have more data with LapTimer that I would like to overlay. I have 2 questions:
1- Can I use the overlay function with the iPhone video while not connected to a network?
2- Will I be able to import the GoPro video and overlay with the 1 session I recorded on the iPhone while off network?
Thanks.
Mark
LapTimer usage while off network
Re: LapTimer usage while off network
1 - yes, overlaying does not require network access
2 - there is no way to do a device 2 device transfer iPhone / GoPro. However, if you have a laptop available, you can transfer the data using a SD card slot, and either iTunes or iBrowse to sync the video to the Photo app (iTunes) or by placing the video directly into LapTimer's Documents folder (iBrowse).
Don't have a Gopro, but recently a friend told me how easy he transfered the video to the iPad for overlaying by using the Gopro App:Harry wrote:2 - there is no way to do a device 2 device transfer iPhone / GoPro. However, if you have a laptop available, you can transfer the data using a SD card slot, and either iTunes or iBrowse to sync the video to the Photo app (iTunes) or by placing the video directly into LapTimer's Documents folder (iBrowse).
http://shop.gopro.com/EMEA/softwareanda ... o-App.html
Check under "compatibility", it depends on the video mode used if the copying will work or not.
Thanks Harry. Now I can go get the new phone, delete everything except LapTimer and the GoPro app and finish what I want.Harry wrote:1 - yes, overlaying does not require network access
fine for low res videos, but times out a lot on hi-res - not worth it imobulls23 wrote:Don't have a Gopro, but recently a friend told me how easy he transfered the video to the iPad for overlaying by using the Gopro App:Harry wrote:2 - there is no way to do a device 2 device transfer iPhone / GoPro. However, if you have a laptop available, you can transfer the data using a SD card slot, and either iTunes or iBrowse to sync the video to the Photo app (iTunes) or by placing the video directly into LapTimer's Documents folder (iBrowse).
The nice thing about the GoPro app is that it does format conversion too. However, that's probably also why it's slow.
