From analysis/ track list/ User track set. The only POI was the start/finish trigger used to create the track. Can edit it, but can't create more for splits or corner info
Am i missing something here?
how to add POI and splits to a new custom track
Re: how to add POI and splits to a new custom track
The s/f trigger is everything needed. This is the reason LapTimer's assistants support only these. To add more POIs, there are several options. As an example, goto Analysis ‣ Realtime ‣ Map. Drag the maps center to the place you want to add a POI to and press the + sign. Fill in the details. Make sure you select your track set as the set containing this new POI / trigger. Back in Map you can fine adjust the POI position be dragging it around.
